Forum Moderators Topics Posts Last Post
   LOGic Support
No New Posts
FAQ
Check here first for info related to installing and using LOGic. You may post here, but only comments or questions requesting clarification on the FAQ, or to post your own FAQ entries. Post questions in the support forums.
Moderator 37 91 Error message from the website when renewing
by WN4AZY  Go to last postGo to last unread
5/20/2026 5:48:01 PM(UTC)
No New Posts
Instructions and support for installing LOGic 9 and upgrading from LOGic 8
Moderator 131 594 License Renewal buster
7/26/2026 10:04:31 AM(UTC)
No New Posts
 (1 Viewing)
Questions about general QSO logging
Moderator 110 502 Incoming Spots cause logging and other delays
by K8ZM  Go to last postGo to last unread
Yesterday at 4:40:09 PM(UTC)
No New Posts
 (1 Viewing)
Discussion of contesting
Moderator 72 258 Progress 2 window for Multipliers
4/7/2026 10:15:52 AM(UTC)
No New Posts
 (2 Viewing)
Discussion of LOGic's awards tracking features
Moderator 107 485 10-10 Processing does not work
11/5/2026 2:24:04 PM(UTC)
No New Posts
 (2 Viewing)
Questions and discussions of callbook databases and LOGic's callbook feature
Moderator 61 286 callbook to log error
by N7IP  Go to last postGo to last unread
9/22/2025 11:32:09 PM(UTC)
No New Posts
Check here for help getting your radio talking to LOGic. Includes CW keying.
Moderator 102 513 Connect to radio via LAN
8/24/2026 4:10:27 PM(UTC)
No New Posts
Discussion of LOGic's spotting features
Moderator 158 763 Add Current Mode?
9/10/2026 10:10:39 AM(UTC)
No New Posts
Discussion of user-defined fields
Moderator 34 156 USEFIELD limit - missing data
9/18/2026 12:52:07 PM(UTC)
No New Posts
Changing form layout, colors, fonts...
Moderator 33 128 Multiple Mainforms informations
by IK0CHU  Go to last postGo to last unread
9/10/2026 5:41:29 PM(UTC)
No New Posts
Running and Modifying LOGic's reports
Moderator 98 395 Dymo QSL Label for Multi QSO/Operators
by N6DHZ  Go to last postGo to last unread
Yesterday at 10:47:26 AM(UTC)
No New Posts
 (1 Viewing)
Post questions about importing and exporting data here.
Moderator 104 489 FOC import not working
by N5XZ  Go to last postGo to last unread
8/19/2026 2:29:32 PM(UTC)
No New Posts
Discussion of mass data changes using LOGic'sTools/Advanced/Database Commands feature. Also writing your own utilities and interfaces to LOGic
Moderator 3 10 Accessing user-defined fields via LOGic's COM...
7/15/2014 10:04:08 AM(UTC)
No New Posts
 (2 Viewing)
Questions about installing LOGic, moving it to another computer, creating new databases, and installing updates
Moderator 46 245 v10.00.35 no Release Notes
7/31/2026 12:57:54 PM(UTC)
No New Posts
If you get an error message, check for the solution here. Use this forum for general error messages. If the message is about a particular feature, such as rig control or EQSL/LoTW, post in the appropriate forum for that feature.
Moderator 141 751 Error Message In PDA Logic 10 Logging Program...
by Rowland  Go to last postGo to last unread
9/10/2026 8:48:28 AM(UTC)
No New Posts
 (1 Viewing)
Post questions and get answers about LoTW here
Moderator 71 460 I screwed up
9/18/2026 7:03:37 AM(UTC)
No New Posts
 (1 Viewing)
Disscuss eQSL here
Moderator 44 324 Download from Eqsl.cc
6/15/2026 2:04:09 PM(UTC)
No New Posts
 (5 Viewing)
Place posts that do not fit on other topics here
Moderator 274 1,126 Forum posts getting deleted
Yesterday at 1:06:47 AM(UTC)
Mark all forums as read
  Active Discussions
Latest Posts
New Posts  Incoming Spots cause logging and other delays  by  K8ZM (Logging) Yesterday at 4:40:09 PM(UTC) Go to last post Go to last unread
New Posts  Dymo QSL Label for Multi QSO/Operators  by  N6DHZ (Report Writer) Yesterday at 10:47:26 AM(UTC) Go to last post Go to last unread
New Posts  Forum posts getting deleted  by  K8ZM (All Other) Yesterday at 1:06:47 AM(UTC) Go to last post Go to last unread
New Posts  10-10 Processing does not work  by  WN4AZY (Awards Tracking) 11/5/2026 2:24:04 PM(UTC) Go to last post Go to last unread
New Posts  Logic 10 Problems  by  IK0CHU (Logging) 10/14/2026 11:35:07 AM(UTC) Go to last post Go to last unread
New Posts  List of valid values  by  WN4AZY (All Other) 10/5/2026 8:03:06 PM(UTC) Go to last post Go to last unread
New Posts  Logging a QSO working split  by  N5XZ (Logging) 10/2/2026 10:32:59 AM(UTC) Go to last post Go to last unread
New Posts  printer search  by  W5GA (All Other) 9/30/2026 7:38:57 PM(UTC) Go to last post Go to last unread
New Posts  USEFIELD limit - missing data  by  K8ZM (User-defined fields) 9/18/2026 12:52:07 PM(UTC) Go to last post Go to last unread
New Posts  POTA Spot Log issues  by  WN4AZY (Logging) 9/18/2026 7:04:08 AM(UTC) Go to last post Go to last unread
New Posts  I screwed up  by  WN4AZY (Logbook of The World) 9/18/2026 7:03:37 AM(UTC) Go to last post Go to last unread
New Posts  Multiple Mainforms informations  by  IK0CHU (Form customization) 9/10/2026 5:41:29 PM(UTC) Go to last post Go to last unread
New Posts  Add Current Mode?  by  WN4AZY (Spotting) 9/10/2026 10:10:39 AM(UTC) Go to last post Go to last unread
New Posts  LoTW woes again  by  WN4AZY (Logbook of The World) 9/10/2026 9:38:10 AM(UTC) Go to last post Go to last unread
New Posts  Error Message In PDA Logic 10 Logging Program FTMGR.CAT=0  by  Rowland (Error Messages) 9/10/2026 8:48:28 AM(UTC) Go to last post Go to last unread
New Posts  Cluster information  by  W5GA (All Other) 8/28/2026 1:51:01 PM(UTC) Go to last post Go to last unread
New Posts  Connect to radio via LAN  by  WN4AZY (Radio & Rotor Interfacing Help & Troubleshooting) 8/24/2026 4:10:27 PM(UTC) Go to last post Go to last unread
New Posts  FOC import not working  by  N5XZ (Import and Export) 8/19/2026 2:29:32 PM(UTC) Go to last post Go to last unread
New Posts  Absence  by  WN4AZY (Forum news and announcements) 8/17/2026 7:13:37 PM(UTC) Go to last post Go to last unread
New Posts  C2 is now the Republic of Naoero  by  W5GA (All Other) 8/3/2026 5:16:15 PM(UTC) Go to last post Go to last unread
New Posts  Print LOGic version in a report  by  WN4AZY (Report Writer) 8/3/2026 9:33:30 AM(UTC) Go to last post Go to last unread
New Posts  v10.00.35 no Release Notes  by  K8ZM (Installation & Updating) 7/31/2026 12:57:54 PM(UTC) Go to last post Go to last unread
New Posts  New annual update install  by  WN4AZY (Installation & Updating) 7/31/2026 10:24:26 AM(UTC) Go to last post Go to last unread
New Posts  WebDriver errors  by  WN4AZY (Error Messages) 7/26/2026 11:28:36 AM(UTC) Go to last post Go to last unread
New Posts  License Renewal buster  by  WN4AZY (LOGic 9 Installation and Upgrading) 7/26/2026 10:04:31 AM(UTC) Go to last post Go to last unread
  Information
Active Users
30 active users, 30 guests for last 5 minutes
Most users ever online was 25876, 7/3/2026 6:43:50 PM(UTC).
Statistics
There are 9,905 posts in 2,112 topics in 43 forums.
Last post Yesterday at 4:40:09 PM(UTC) by K8ZM.
We have 1,071 registered members.
The newest member is Fowler Jakub.
New Posts No New Posts Forum Locked
This page was generated in 0.097 seconds.
