Eqsl always Eqsl ...
#1 Posted : Wednesday, October 23, 2019 4:28:32 AM(UTC)
now what is the new?
Is it a general problem or only mine for about 7 hours? A new Windows update?
Thanks for ant idea.
73's de IK0CHU Mauro
W7HO
#2 Posted : Wednesday, October 23, 2019 2:36:55 PM(UTC)
I am getting the same error message when trying to import from eQSL.
Thanks Ron W7HO
KD0PO
#3 Posted : Wednesday, October 23, 2019 9:01:12 PM(UTC)
dokxray
make that 3 of us
Ray
NU1B
#4 Posted : Friday, October 25, 2019 6:13:11 AM(UTC)
Hi Dennis
I have same problem
Steve, NU1B
W8OI
#5 Posted : Friday, October 25, 2019 8:08:31 AM(UTC)
Same here. I get the same message from eQSL. Error message says "This adif file is not from eQSL. Cannot import."
I have LOGic running on three computers and all get the same message when I try to import eQSLs. Export to eQSL still works fine. My computers are running the latest LOGic update. Any help would be appreciated.
#6 Posted : Monday, October 28, 2019 12:14:32 PM(UTC)
Just an FYI from N5UP at eQSL in a related question from another logger;
---If your logger started failing to find the ADIF file generated by DownloadInbox.cfm here is the reason:
---We moved the DownloadedFiles folder to be above the QSLCard folder on October 22, 2019.
---Any external programs that had hardcoded the folder structure might not find the files!
---To prevent any folder structure changes from breaking your program, the hyperlinks on the results page should be followed to the location of the file.
LOGic may have the filepath hardcoded and so is thinking its not from eQSL and thus isn't allowing the import. I'm just guessing and maybe its totally unrelated but the timing of the change is too coincidental to when Mauro first posted this issue on the 23rd. Dennis I'm sure will chime in.
73, de Brad N8GLS
OZ4CG
#7 Posted : Monday, October 28, 2019 1:59:01 PM(UTC)
Carsten Gjessing
Hi all!
I am getting the same message here, when trying to get my eQSL's, so it seems to be a general problem... ??
So how ??
Best 73 Carsten / OZ4CG
#8 Posted : Monday, October 28, 2019 6:34:41 PM(UTC)
Seems to be. I am looking into it.
#9 Posted : Monday, October 28, 2019 9:27:47 PM(UTC)
Fixed. Get the 9.1.44 update. Help/Check for Updates.
OZ4CG on 10/29/2019(UTC), IK0CHU on 11/2/2019(UTC)
OZ4CG
#10 Posted : Tuesday, October 29, 2019 7:39:35 AM(UTC)
Carsten Gjessing
Hi Dennis
Seems that eQSL makes a great effort to keep you busy BigGrin
I downloaded the ver. 44, and all seems to work now!
Many thanks for your action!
At the same time I will thank you for de new delayed download, that works brilliant! Now it is possible to study the eQSLs coming into the log during the download as well! Fine!
#11 Posted : Saturday, November 2, 2019 12:08:35 PM(UTC)
thank you for your valuable support for every problem.
#12 Posted : Wednesday, November 6, 2019 4:09:53 PM(UTC)
Thanks for all your help and everything you do!
W8OI
#13 Posted : Friday, January 24, 2020 9:22:13 AM(UTC)
Another eQSL problem has developed for me. I can no longer upload through LOGic. I can still download but cannot send my log to eQSL. It has been that way for sometime now. Am I alone in having this experience?
#14 Posted : Friday, January 24, 2020 7:48:54 PM(UTC)
I haven't had a problem. Can you login on the website ok? To make sure you're using the right username/password.
WN4AZY on 2/12/2020(UTC)
W8OI
#15 Posted : Friday, January 24, 2020 9:43:10 PM(UTC)
Yes, and remember I can download just fine using my password in LOGic.
#16 Posted : Saturday, January 25, 2020 7:58:22 AM(UTC)
What version of LOGic are you using? Do you get any errors? I uploaded this morning using 9.1.46 with no issues.
W8OI
#17 Posted : Saturday, January 25, 2020 8:39:48 AM(UTC)
I am also using 9.1.46. I have tried uploading many time on two different compuI am also using 9.1.46. I have tried uploading many time on two different computers and always get this same message.ters and always get the same message telling me there is no match.
W8OI
#18 Posted : Saturday, January 25, 2020 8:59:32 AM(UTC)
NEVER MIND, PROBLEM SOLVED.
Since the problem was obviously on my end, I did some investigating and found out that my eQSL profile contained an end date for my call of January 14, 2020. I simply extended that end date to the year 2034. Now I can upload to eQSL again.
#19 Posted : Saturday, January 25, 2020 12:13:02 PM(UTC)
Glad you got it working and thanks for sharing your fix. Now you have a lot of new QSLs!
This page was generated in 0.076 seconds.
