Posts: 33 Location: So. Ca.
Thanks: 1 times Was thanked: 15 time(s) in 14 post(s)
Unhide a user-defined field, say continent and the box and drop down list show up in the log form correctly but the name of the field doesn't. I tried several user-defined fields and the same happens. I'm sure the fix is something simple but I'm missing it. Thanks in advance for the help. DE N6DHZ
Posts: 618 Location: Mentor, OH
Thanks: 150 times Was thanked: 235 time(s) in 212 post(s)
Hi James, The label for the user defined field also needs to be unhid. In the example attached, userfield 4 is the continent, its label (prefixed with the capital letter A) just needs to be dragged to the unhide button. If you tried that already and its not appearing let us know, it could be that the label is "outside" of the visible logform window. Brad, N8GLS
Thanks Brad, I was right there. It's been years since I needed to make a change to the log form and only remembered half of the procedure. 73 DE Jim, N6DHZ
Jim,
Your not alone !! Can't count all the times I had to post a question here for the same reason.
73 de Brad, N8GLS
