Field Name Missing
N6DHZ
#1 Posted : Tuesday, July 16, 2019 12:14:51 AM(UTC)
jshryne
Unhide a user-defined field, say continent and the box and drop down list show up in the log form correctly but the name of the field doesn't. I tried several user-defined fields and the same happens. I'm sure the fix is something simple but I'm missing it.
Thanks in advance for the help.
DE N6DHZ
#2 Posted : Tuesday, July 16, 2019 4:26:24 PM(UTC)
Hi James,
The label for the user defined field also needs to be unhid. In the example attached, userfield 4 is the continent, its label (prefixed with the capital letter A) just needs to be dragged to the unhide button.
If you tried that already and its not appearing let us know, it could be that the label is "outside" of the visible logform window.
Brad, N8GLS
LOGic Userfield Label-1.JPG (218kb) downloaded 164 time(s).
LOGic Userfield Label-2.JPG (119kb) downloaded 173 time(s).
WN4AZY on 7/18/2019(UTC)
N6DHZ
#3 Posted : Wednesday, July 17, 2019 3:24:15 PM(UTC)
jshryne
Thanks Brad, I was right there. It's been years since I needed to make a change to the log form and only remembered half of the procedure.
73 DE Jim, N6DHZ
#4 Posted : Wednesday, July 17, 2019 4:10:15 PM(UTC)
Jim,
Your not alone !! Can't count all the times I had to post a question here for the same reason.
73 de Brad, N8GLS
