LOGic Forum
LOGic Support
Awards Tracking
80m DXCC not showing as needed
Groups: Registered, Beta Testers Posts: 503 Location: Richmond, TX
Thanks: 44 times Was thanked: 89 time(s) in 84 post(s)
FH is not showing up as being needed on 80 but it appears that my setup should alert me. See attached. What am I doing wrong? 73, Allen N5XZ
The setup appears correct.
I can't see the entire spot log is the call being recognized as Mayotte?. What is listed in the DXCC Description column?
Groups: Administrators, Beta Testers Posts: 3,266  Location: Auburn, GA Thanks: 1145 times Was thanked: 555 time(s) in 465 post(s)
Also search your log for all QSOs where DXCC is FH and browse thru them. Also try AWARDS/UPDATE AWARDS PROGRESS INFO. You can test by creating a test spot on the Options tab. Let me know. If nothing turns up you can call me and I can log in and take a look. http://www.hosenose.com/remote_support.aspx
Another thought -- are you expecting to receive a spot announcement saying it is needed, or an alert -- as in the ALerts tab on the spot log? Tnx & 73, Dennis WN4AZY
What I didn't show was the progress for DXCC window which shows FH as unwworked on 80m so I would have expected it to be highlighted in the spot log and to receive an alert. I'll check it again when I get a chance and will perhaps have you remote it. As I am out of town, I would also have to remote in. I wonder if we both can simultaneously...? i use Teamviewer. 73, Allen N5XZ
Ok, let me know. I use teamviewer occasionally.
LOGic Forum
LOGic Support
Awards Tracking
