80m DXCC not showing as needed
#1 Posted : Tuesday, February 19, 2019 9:21:04 PM(UTC)
FH is not showing up as being needed on 80 but it appears that my setup should alert me. See attached.
What am I doing wrong?
#2 Posted : Wednesday, February 20, 2019 8:01:31 AM(UTC)
The setup appears correct.
I can't see the entire spot log is the call being recognized as Mayotte?. What is listed in the DXCC Description column?
WN4AZY on 2/20/2019(UTC)
#3 Posted : Wednesday, February 20, 2019 5:56:11 PM(UTC)
Also search your log for all QSOs where DXCC is FH and browse thru them. Also try AWARDS/UPDATE AWARDS PROGRESS INFO.
You can test by creating a test spot on the Options tab.
Let me know. If nothing turns up you can call me and I can log in and take a look.
Another thought -- are you expecting to receive a spot announcement saying it is needed, or an alert -- as in the ALerts tab on the spot log?
#4 Posted : Friday, February 22, 2019 10:10:51 AM(UTC)
What I didn't show was the progress for DXCC window which shows FH as unwworked on 80m so I would have expected it to be highlighted in the spot log and to receive an alert. I'll check it again when I get a chance and will perhaps have you remote it. As I am out of town, I would also have to remote in. I wonder if we both can simultaneously...? i use Teamviewer.
#5 Posted : Thursday, February 28, 2019 10:07:45 AM(UTC)
Ok, let me know. I use teamviewer occasionally.
