Program Error
w3fq
#1 Posted : Saturday, December 31, 2016 10:17:03 AM(UTC)
Error when sending spots, "program error, unknown member, ERROREDITBOX"
Error 4.PNG (7kb) downloaded 92 time(s).
#2 Posted : Tuesday, January 3, 2017 3:36:34 PM(UTC)
Thanks for the error report.
Please give me more info.
1. Exact steps to reproduce the error. (I tried sending a spot from the Telnet window, and no problems.)
2. The version of LOGic that you are using (help/about). Was it introduced by the 9.1.7 update?
w3fq
#3 Posted : Tuesday, January 3, 2017 3:56:39 PM(UTC)
I am using the latest update 9.1.7, and every time I tried sending a spot I received this error message.
Jim,
W3FQ
w3fq
#4 Posted : Tuesday, January 3, 2017 3:58:58 PM(UTC)
I was using the DxScape window when sending the sopt.
Jim,
W3FQ
w3fq
#5 Posted : Tuesday, January 3, 2017 4:43:18 PM(UTC)
These errors didn't happen before loading 9.1.7
Jim,
W3FQ
#6 Posted : Monday, January 9, 2017 11:11:24 AM(UTC)
Sorry for the delay on this. It took a while to research and "fix" it.
It turns out that the problem is apparently with the DXScape server, and coincidental with installing 9.1.7. I installed 9.1.6 and got the same error.
There was an error in LOGic that prevented it from properly reporting a server error. Install the 9.1.8, and it reports "ERROR CONNECTING" or something like that, coming from the DXScape server.
I will look into how to post a spot to DXScape. Perhaps you have to log in now or something. If anyone knows, please let me know.
#7 Posted : Monday, January 9, 2017 8:18:16 PM(UTC)
Hi Guys,
DXscape requires the callsign and password from the spotter along with the spotted stations info (callsign, freq, and remarks/comments). After clicking on "send spot" you get the pop-up window with the fields to be filled in. Jpeg attached.
73, de Brad, N8GLS
DXScape Spot Window.JPG (34kb) downloaded 89 time(s).
w3fq
#8 Posted : Tuesday, January 10, 2017 4:30:20 PM(UTC)
Originally Posted by: n8gls Go to Quoted Post
Hi Guys,
73, de Brad, N8GLS
Sorry Brad,
But I am no offered a pop up that has a field as you mentioned, no password, etc.
73, Jim W3FQ
#9 Posted : Tuesday, January 10, 2017 5:30:43 PM(UTC)
Maybe after you post your first spot and successfully provide the proper callsign and password, it no longer asks for the callsign and password?
Anyway, it looks like a simple HTML form that does a POST. Shouldn't be a problem.
http://www.dxscape.com/sendspot/
#10 Posted : Saturday, January 14, 2017 10:56:02 PM(UTC)
Went to sign up to post spots, and it won't let me use my email address. You have to use @ARRL.ORG @QTH.NET etc. So waiting for that to get set up.
Guest (7)
