Stop spot log from showing FFMA as needed on bands other than 6m
AK3E
#1 Posted : Saturday, November 14, 2015 12:53:45 PM(UTC)
Subject should explain it. Want to stop FFMA showing as needed for bands other than 6m.
Thanks AK3E
#2 Posted : Sunday, November 15, 2015 1:49:47 PM(UTC)
Make sure your FFMA is set up like the attached photo. It should only spot 6M.
Are you getting actual FFMA spots (FFMA in the Awards column of the spot log), or is it actually spotting Grid?
AK3E
#3 Posted : Sunday, November 15, 2015 3:39:54 PM(UTC)
My calculated field expression was different than yours.
It was ALLTRIM(LEFT(GRID,4))
Changed it so will see what happens.
An example spot is CX90IARU (award) FFMA (mode in red) CW (value)CN84 (band in red) 10m (spot by) WB8VLC
Rick AK3E
