LOGic Forum
LOGic Support
Spotting
Stop spot log from showing FFMA as needed on bands other than 6m
Subject should explain it. Want to stop FFMA showing as needed for bands other than 6m. Thanks AK3E
Hi-- Make sure your FFMA is set up like the attached photo. It should only spot 6M. Are you getting actual FFMA spots (FFMA in the Awards column of the spot log), or is it actually spotting Grid? 73, Dennis WN4AZY
Thanks Dennis, My calculated field expression was different than yours. It was ALLTRIM(LEFT(GRID,4)) Changed it so will see what happens. An example spot is CX90IARU (award) FFMA (mode in red) CW (value)CN84 (band in red) 10m (spot by) WB8VLC Rick AK3E
LOGic Forum
LOGic Support
Spotting
