TRX Manager
KT7AZ
#1 Posted : Monday, January 23, 2012 11:26:38 PM(UTC)
Good job on rig interface fix. I have been using TRX-Manger with Logic 8 and now with Logic 9.
I find Logic is now locking up when I add a new QSO with TRX-Manager running. my error is as follows:
Program Error
OLE error code 0x80010004: It is illegal to call out while inside message filter.
I then get a popup that says:
LOGIC 9
This action cannot be completed because th "FTLink program is not responding.
Choose "Switch to" and correct the problem.
When I click "switch to" the above error keeps repeating.
I also notice now that when I close TRX-Manger Logic 9 now closes.
Gary
KT7AZ
#2 Posted : Tuesday, January 24, 2012 9:55:52 AM(UTC)
Ok, I can't reproduce that here. Does LOGic 8 still work?
I'll see if this means anythkng to Laurent.
KT7AZ
#3 Posted : Tuesday, January 24, 2012 9:49:40 PM(UTC)
Logic 8 is working properly with TRX Manager. I do use TRX Manager for rig control for Logic 8 and am trying in Logic 9 but with the above issue.
TNX
Gary
KT7AZ
KT7AZ
#4 Posted : Tuesday, January 24, 2012 11:48:17 PM(UTC)
I have been trying a few things and I notice that if I start TRX Manager prior to Logic 9 I am able to add a QSO about one half of the time. The other times it fails as before.
Gary
KT7AZ
