Posts: 5 Location: Oro Valley, AZ
Good job on rig interface fix. I have been using TRX-Manger with Logic 8 and now with Logic 9. I find Logic is now locking up when I add a new QSO with TRX-Manager running. my error is as follows:
Program Error OLE error code 0x80010004: It is illegal to call out while inside message filter.
I then get a popup that says:
LOGIC 9
This action cannot be completed because th "FTLink program is not responding. Choose "Switch to" and correct the problem.
When I click "switch to" the above error keeps repeating.
I also notice now that when I close TRX-Manger Logic 9 now closes.
Gary KT7AZ
Ok, I can't reproduce that here. Does LOGic 8 still work?
I'll see if this means anythkng to Laurent.
Logic 8 is working properly with TRX Manager. I do use TRX Manager for rig control for Logic 8 and am trying in Logic 9 but with the above issue.
TNX Gary KT7AZ
I have been trying a few things and I notice that if I start TRX Manager prior to Logic 9 I am able to add a QSO about one half of the time. The other times it fails as before.
Gary KT7AZ
