BandMap.config
k6mi
#1 Posted : Monday, February 16, 2015 11:44:09 AM(UTC)
Logic 9.71 now gives me:
OLE IDispatch exception code O from Sytem.Configuration Root element is missing.(c):Program Files\:LOGic\BandMap.config)..
Band map, and LOTW download no longer work, although LOTW upload is still ok.
Windows XP. I've reloaded the program, (basic and update) and then tried uninstalling and then reloading, but it all is the same.
Any help?
John, K6MI
#2 Posted : Monday, February 16, 2015 5:32:07 PM(UTC)
It sounds like the bandmap.config file got corrupted somehow. Just delete it, and LOGic will make a new one. It is located in C:\Program Files (x86)\LOGic or C:\Program Files\LOGic.
You will have to redo any band map settings.
DH WN4AZY
k6mi
#3 Posted : Monday, February 16, 2015 5:46:20 PM(UTC)
Thanks, worked perfect, bandmap and LOTW download are restored.
k6mi
#4 Posted : Friday, September 27, 2019 2:17:57 PM(UTC)
Looked at the reply from four years ago and it brought back the bandmap.
So far that seems to fix everything.
Thanks, John K6MI
