Microsoft.NET Framework error
W8OI
#1 Posted : Tuesday, February 12, 2013 3:40:09 PM(UTC)
Suddenly I began getting this new error message today whenever I tried to run the LOGic World Map.
At the top of the box it says "Microsoft.NET Framework" The body of the message in the box says "Unhandled exception has occured in a component in your application. If you click Continue, the applicaton will ignore this error and attempt to continue. Root element is missing (C:\Program Files (x86) \LOGic\WorldMap.config)."
Clicking continue gets me nowhere and this message stays on the screen. Only way to remove it is by using Windoqws Task Master to end LOGic.
I did a complete uninstall of LOGic and then reinstalled. Did not help. What can I do, please? System is Windows 7.
#2 Posted : Tuesday, February 12, 2013 8:16:11 PM(UTC)
Sorry for the problem.
Try deleting worldmap.config. It is located
in the install folder C:\Program Files (x86)\LOGic\ or C:\Program Files\LOGic\
W8OI
#3 Posted : Tuesday, February 12, 2013 9:52:06 PM(UTC)
Dennis:
Thank you so much. That worked. All is as it should be again.
Garry, W8OI
