LOGic Forum
LOGic Support
Error Messages
Microsoft.NET Framework error
Posts: 55 Location: Huntington, WV
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Suddenly I began getting this new error message today whenever I tried to run the LOGic World Map. At the top of the box it says "Microsoft.NET Framework" The body of the message in the box says "Unhandled exception has occured in a component in your application. If you click Continue, the applicaton will ignore this error and attempt to continue. Root element is missing (C:\Program Files (x86) \LOGic\WorldMap.config)."
Clicking continue gets me nowhere and this message stays on the screen. Only way to remove it is by using Windoqws Task Master to end LOGic.
I did a complete uninstall of LOGic and then reinstalled. Did not help. What can I do, please? System is Windows 7.
Groups: Administrators, Beta Testers Posts: 3,205  Location: Auburn, GA Thanks: 1103 times Was thanked: 530 time(s) in 443 post(s)
Sorry for the problem.
Try deleting worldmap.config. It is located in the install folder C:\Program Files (x86)\LOGic\ or C:\Program Files\LOGic\
Dennis:
Thank you so much. That worked. All is as it should be again.
Garry, W8OI
LOGic Forum
LOGic Support
Error Messages
