Groups: Administrators, Beta Testers Posts: 3,257  Location: Auburn, GA Thanks: 1135 times Was thanked: 554 time(s) in 464 post(s)
Since you are using {Enter} to "save" the new QSO, I asume you have "{Enter} Adds a new QSO" selected in log/setup. Check this.
Ok, so you type a call and press {Tab}, it gets the current time. All good. You finish out the QSO, you press {Enter}, and it blanks the log screen, starts a new QSO, and enters the current time for you. You enter a call and press {Tab} it will again read the clock. But the QSO that was on tehscreen before you pressed {Enter} IS saved with the correct time. You just can't see it in the log entry form because you just started a new QSO by pressing {Enter}. You can also double-click the Time fields to populate with the current time.
Note that you do not have to explicitly save a QSO in LOGic. It will get saved when you add a new QSO, close the log screen, etc. Saving does read the clock for time-off. There is a Save button to force this and to attempt to flush the disk buffers in case of power failure etc.
Let me know if any ????s.
