install call sign
#1 Posted : Wednesday, July 16, 2025 10:40:57 AM(UTC)
Was thanked: 155 time(s) in 138 post(s)
I was trying to figure out why the installation of LOGic I had installed on my wife's (W5TAT) computer kept putting my call in the main log form operator screen, when it showed her call in station info. So, I think I may have found out why....I backed her logdata up, and wiped her installation out, so I could start over. Once I had things reinstalled, and I was configuring the log info page, I put her call in and got the attached error message. I was using my backed up license that Fe sent earlier this year.
#2 Posted : Wednesday, July 16, 2025 10:07:59 PM(UTC)
Sorry for the problem.
Look in LOG/Setup, GENERAL tab, OPERATOR field. It overrides the setting in Station Info.
(Not accepting her call)
Please look at the license file logic.license. It is just a text file. See if W5TAT is listed. My guess it is an old license file. If so, I can make you a new one.
Let us know.
#3 Posted : Thursday, July 17, 2025 8:31:54 AM(UTC)
Thanks, Dennis. The license file shows both calls as "W5GA, W5TAT" exactly as I've typed them. And the call field in log/setup/general is blank, so it should default to the call in Tools/setup/station info, correct?
73, Doug W5GA
#4 Posted : Sunday, July 20, 2025 6:44:03 AM(UTC)
73, Doug W5GA
IF Log/Setup/General/Operator is blank.
#5 Posted : Sunday, July 20, 2025 8:51:09 AM(UTC)
So, after messing around a bit....it demands that I put both calls in the tools/setup/station info/your callsign box....just as spelled out in the license file; W5GA, W5TAT. It will not accept w5tat by itself. It will accept w5ga by itself. The same is true for log/setup/general/operator. I need it to accept W5TAT by itself.
#6 Posted : Monday, July 21, 2025 1:19:56 PM(UTC)
OK, my fault. I remade the license file. Please re-download and re-install your update.
I apologize.
W5GA on 7/21/2025(UTC)
#8 Posted : Monday, July 21, 2025 5:49:31 PM(UTC)
Can I get a link to download it, please? I no longer have the one Fe sent me.
Doug
#9 Posted : Tuesday, July 22, 2025 6:04:47 AM(UTC)
I resent it.
W5GA on 7/22/2025(UTC)
#10 Posted : Tuesday, July 22, 2025 8:45:37 AM(UTC)
Yup, the new license file fixed it. Thanks, Dennis!!
73 Doug W6GA
WN4AZY on 7/25/2025(UTC)
