Posts: 3 Location: Massachusetts
Is there an easy way to create a sub log out of my main log? My main log has nearly 10K entries and I would like to delete most of the entries except a select group of them.
Groups: Administrators, Beta Testers Posts: 3,258  Location: Auburn, GA Thanks: 1138 times Was thanked: 554 time(s) in 464 post(s)
Hi Dave, Sure, no problem. Set up a second database which is a copy of your main log. Here is info on how to do that: https://www.hosenose.com...ate-a-new-database.aspx
https://youtu.be/9EYu0rfCM1w
Then fire LOGic up so that it accesses the copy you made. Delete the records you do not want. You can do bulk deletes in tools/setup/database commands. https://youtu.be/5d5gyJVFQEs
Please subscribe to our youtube channel while you are there. Let me know if any questions. Tnx & 73, Dennis WN4AZY
