Creating a log
K1MT
#1 Posted : Thursday, February 10, 2022 3:04:55 PM(UTC)
Is there an easy way to create a sub log out of my main log? My main log has nearly 10K entries and I would like to delete most of the entries except a select group of them.
#2 Posted : Friday, February 11, 2022 4:13:30 PM(UTC)
Hi Dave,
Sure, no problem. Set up a second database which is a copy of your main log. Here is info on how to do that:
https://www.hosenose.com...ate-a-new-database.aspx
https://youtu.be/9EYu0rfCM1w
Then fire LOGic up so that it accesses the copy you made. Delete the records you do not want. You can do bulk deletes in tools/setup/database commands.
https://youtu.be/5d5gyJVFQEs
Please subscribe to our youtube channel while you are there.
