Builk database change using a selection
WD4ASP
#1 Posted : Wednesday, February 2, 2022 8:31:49 PM(UTC)
I am getting ready to print out QSL labels for the first time and would like PSE or TNX to print out on the contact line. It appears in order to get PSE to print out, the QSL_RCVD field needs to have an R in it. Likewise QSL_RCVD needs to have an 'F' in it for TNX.
What I would like to do, using the selection that is being use to select the QSOs for labels, is use that same selection to set the QSO_RCVD field to 'R'. I would set the QSL_RCVD field to 'F' prior to the label selection.
Below is an example selection statement.
LOTW_RCVD<>'F' AND (MODE='SSB' or mode='USB' or mode='LSB') AND QSO_DATE>={^2000-01-01} AND NOT EMPTY(VIA) AND QSL_RCVD<>'F'
Is there a way to do this automagically or does it need to be done manually.
Fred
#2 Posted : Thursday, February 3, 2022 4:52:32 PM(UTC)
So do I understand correctly that you want to change some QSL_RCVD fields en masse?
Your select statement looks good. In English, No QSL or LOTW QSL Rcvd, QSO DATE in this millenium, VIA is not blank, and MODE is sideband.
MAKE A BACKUP!!!
Go to tools/advanced/database commands. Type (or copy and paste)
USE LOG
REPLACE QSL_RCVD WITH "R" FOR LOTW_RCVD<>'F' AND (MODE='SSB' or mode='USB' or mode='LSB') AND QSO_DATE>={^2000-01-01} AND NOT EMPTY(VIA) AND QSL_RCVD<>'F'
There is a video here:
https://youtu.be/5d5gyJVFQEs
Pse subscribe to our Youtube channel while you are there.
WD4ASP
#3 Posted : Thursday, February 3, 2022 8:05:51 PM(UTC)
Thanks for getting back to me so quickly. I tried to use the Database files->Mass change->Replace field contents and pasted in my selection criteria:
However there appears to be a length limit because only the following got pasted in:
LOTW_RCVD<>'F' AND (MODE='SSB' OR MODE='USB' OR MODE='LSB') AND QSO_DATE>={^2000-01-01} AND NOT EMPTY(VIA) AND QSL_RCVD<
This is 120 bytes and I need at least 124.
I wanted to use the Replace field contents so I could verify the number of records that would be changed and also look at them like in the video.
Fred
WN4AZY on 2/6/2022(UTC)
#4 Posted : Sunday, February 6, 2022 9:11:52 PM(UTC)
Ok, I will increase the size of this field in the next update.
In the meantime, just use the command box as per my first response to this thread.
WD4ASP
#5 Posted : Tuesday, February 8, 2022 11:22:50 PM(UTC)
Followed your suggestions and they worked like a champ.
Fred
WN4AZY on 2/9/2022(UTC)
