Posts: 41 Location: Torrington, Ct
Hi Dennis
I upgraded to 10.0.4 and I get the following error message wgen start the program
Error 1925 "Unknown Member Map _ REF" has occurred in program Spotlog.set band filter, Line 3
If I select yes to continue the program works okay. If I select no, the program closes. When you restart program after it close, the program goes through the cleaning cycle and then restarts with no error message
What do I need to do to eliminate this error message.
Steve, NU1B
1 user thanked NU1B for this useful post.
Hi Dennis
I indicated the program worked fine if you selected yes after error message. That is correct until clip on a spot in spot log and then clip in set rig frequency then you an error message about map. If you clip on ignore error, the program works fine until you clip on a spot and then clip on set frequency then you get error message again.
I have reinstalled 10.0.3 untill iI hear from you on how to fix this error
Steve, NU1B
Groups: Administrators, Beta Testers Posts: 3,257  Location: Auburn, GA Thanks: 1135 times Was thanked: 554 time(s) in 464 post(s)
Sorry for the bug. That happens when Forms/World Map is not open.
I fixed it. Please download and install 10.0.4 again.
Hi Dennis
I reinstalled 10.0.4 and have no errpr messages
Thanks for your help
Steve, NU1B
