Ver 10.0.4
NU1B
#1 Posted : Friday, January 14, 2022 1:40:09 PM(UTC)
Hi Dennis
I upgraded to 10.0.4 and I get the following error message wgen start the program
Error 1925 "Unknown Member Map _ REF" has occurred in program
Spotlog.set band filter, Line 3
If I select yes to continue the program works okay. If I select no, the program closes. When you restart program after it close, the program goes through the cleaning cycle and then restarts with no error message
What do I need to do to eliminate this error message.
Steve, NU1B
1 user thanked NU1B for this useful post.
WN4AZY on 1/15/2022(UTC)
NU1B
#2 Posted : Friday, January 14, 2022 3:08:54 PM(UTC)
Hi Dennis
I indicated the program worked fine if you selected yes after error message. That is correct until clip on a spot in spot log and then clip in set rig frequency then you an error message about map.
If you clip on ignore error, the program works fine until you clip on a spot and then clip on set frequency then you get error message again.
I have reinstalled 10.0.3 untill iI hear from you on how to fix this error
Steve, NU1B
#3 Posted : Saturday, January 15, 2022 10:59:25 PM(UTC)
Sorry for the bug. That happens when Forms/World Map is not open.
I fixed it. Please download and install 10.0.4 again.
NU1B
#4 Posted : Sunday, January 16, 2022 7:36:54 AM(UTC)
Hi Dennis
I reinstalled 10.0.4 and have no errpr messages
Thanks for your help
Steve, NU1B
WN4AZY on 1/16/2022(UTC)
