Safety Log Problem
K7PDW
#1 Posted : Thursday, September 17, 2020 10:36:31 AM(UTC)
DAVE
I just installed a subscription renewal. My Safety Log failed to load. I had made some changes to my system that accounted for the error. I changed the path to the Safety Log in Setup, closed and reopened Logic the got several errors. I checked that the path was correct this time and it is so I closed and reopened Logic. See attached files.
2020-09-17 (1).png (6kb) downloaded 7 time(s).
2020-09-17 (2).png (7kb) downloaded 7 time(s).
2020-09-17 (3).png (7kb) downloaded 5 time(s).
2020-09-17 (4).png (7kb) downloaded 2 time(s).
2020-09-17 (5).png (7kb) downloaded 3 time(s).
2020-09-17 (6).png (3kb) downloaded 4 time(s).
K7PDW
#2 Posted : Saturday, September 19, 2020 10:40:10 AM(UTC)
DAVE
Set the Safety Log to NONE and I do not get any error on startup but cannot upload to LOTW. Looks like I really broke it.
Suggestions.
K7PDW
#3 Posted : Tuesday, September 22, 2020 11:23:53 AM(UTC)
DAVE
More problems. Now I get an error checking for updates.
This all started when I loaded my subscription renewal.
Help!
#5 Posted : Tuesday, September 22, 2020 2:19:54 PM(UTC)
You should probably give Tech Support a call with the issues you're having.
#4 Posted : Thursday, September 24, 2020 9:55:46 AM(UTC)
Help!
What does the error say?
Where is the safetlylog located? Do you have full write and create rights to that folder?
I will be around. Call 770-307-1496.
