Posts: 85  Location: Syracuse, Utah Thanks: 23 times Was thanked: 13 time(s) in 12 post(s)
I just installed a subscription renewal. My Safety Log failed to load. I had made some changes to my system that accounted for the error. I changed the path to the Safety Log in Setup, closed and reopened Logic the got several errors. I checked that the path was correct this time and it is so I closed and reopened Logic. See attached files. File Attachment(s):  2020-09-17 (1).png (6kb) downloaded 7 time(s). 2020-09-17 (2).png (7kb) downloaded 7 time(s). 2020-09-17 (3).png (7kb) downloaded 5 time(s). 2020-09-17 (4).png (7kb) downloaded 2 time(s). 2020-09-17 (5).png (7kb) downloaded 3 time(s). 2020-09-17.png (6kb) downloaded 4 time(s). 2020-09-17 (6).png (3kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
Set the Safety Log to NONE and I do not get any error on startup but cannot upload to LOTW. Looks like I really broke it. Suggestions.
More problems. Now I get an error checking for updates.
This all started when I loaded my subscription renewal.
Help!
You should probably give Tech Support a call with the issues you're having.
Originally Posted by: K7PDW  More problems. Now I get an error checking for updates.
Help! What does the error say? Where is the safetlylog located? Do you have full write and create rights to that folder? I will be around. Call 770-307-1496. Tnx & 73, Dennis WN4AZY
