Groups: Administrators, Beta Testers Posts: 3,260  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
I just tested this, and no problems here.
Spot level and QSL status doesn't matter. All that matters is that the band and mode match what is in your log, and DAYS AGO hasn't expired. The idea is that if you have worked that station on that band and mode in the last 90 days or whatever, there is no need to to after him again. If you requested a QSL last time you worked him, great. Hopefully he will come thru. If he doesn't, the 90 days expires and he shows as needed. If you worked him before and didn't request a QSL, there is probably a reason -- like he says he doesn't QSL. Again, no need to chase after him again.
Here's how I tested:
A spot comes in. Work him. Log him. Don't worry about QSL SENT/RCVD. Just make sure call, band, mode, and date/time are logged.
Now go to the Options page on the spot log. Generate a test spot of the station that you just worked. Choose a frequency that translates out to the same band and mode of the QSO you just worked. The test spot should show up with a green callsign.
MAKE SURE Show All IS CHECKED!
