Ok, I see the problem.
I will fix my master copy, but in the meantime, do this:
Run LOGic. Close all windows. You can try just closing the spot log window and any spot-related windows such as WebCluster DX Summit.
Click Tools/Advanced/Database commands. Type these two lines, pressing Enter after each line:
USE SPOTS EXCL MODIFY STRUCTURE
Change the width of DXCC_DESCR to 30. (The reason we make it so much longer is that if a station is not found in the callbook, it will say UNITED STATES, CALL DISTRICT 4
Click OK to save your changes. Close the Database Commands window.
