new behaviour in spot log for 9.20.7
#1 Posted : Sunday, June 28, 2020 2:02:11 PM(UTC)
Just installed 9.20.7 and noticed something different in the spot log. The spots for the US say 'UNITED STATES' followed by a single letter. I honestly did not notice this before and don't see that for other (no-US) entries.
WN4AZY on 6/29/2020(UTC)
#2 Posted : Sunday, June 28, 2020 4:00:58 PM(UTC)
Widen the column so you can read the entire field.
w2zi on 6/29/2020(UTC), WN4AZY on 6/29/2020(UTC)
#3 Posted : Sunday, June 28, 2020 6:06:13 PM(UTC)
Hi Kyle:
Make the column a little wider. LOGic attempts to get the station's state from the callbook.
#4 Posted : Monday, June 29, 2020 8:00:07 AM(UTC)
I made the column much wider and I still only see a single letter after 'UNITED STATES,'
The last spot in the screenshot I'm attaching to this reply is wider.
Thanks.
#5 Posted : Monday, June 29, 2020 1:45:35 PM(UTC)
Ok, I see the problem.
I will fix my master copy, but in the meantime, do this:
Run LOGic. Close all windows. You can try just closing the spot log window and any spot-related windows such as WebCluster DX Summit.
Click Tools/Advanced/Database commands. Type these two lines, pressing Enter after each line:
USE SPOTS EXCL
MODIFY STRUCTURE
Change the width of DXCC_DESCR to 30. (The reason we make it so much longer is that if a station is not found in the callbook, it will say UNITED STATES, CALL DISTRICT 4
Click OK to save your changes. Close the Database Commands window.
