Posts: 400  Location: Viterbo, VT - ITALY Thanks: 62 times Was thanked: 91 time(s) in 84 post(s)
Hello Dennis, I often listen to stations operating in split button and select the split of icom 756proIII to find the value of the split. Starting with Logic9, I realized that the split ON is removed from the transceiver to OFF. Sometimes, for this reason, I called isofrequency and I did not look good. Why the split button does not update the data with the equipment? Pressing the split button on the program, the radio will change the setting ON/OFF, if I change the setting from the radio does not make any effect on the program and entering a QSO does not update the frequency split field tx_freq. I'm wrong in something? Thanks de IKØCHU Mauro *** File Attachment(s):  ScreenShot138.jpg (186kb) downloaded 5 time(s). ScreenShot139.jpg (301kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register. IKØCHU Mauro
