Split button on Logic
#1 Posted : Thursday, February 28, 2013 6:52:57 PM(UTC)
Hello Dennis,
I often listen to stations operating in split button and select the split of icom 756proIII to find the value of the split. Starting with Logic9, I realized that the split ON is removed from the transceiver to OFF. Sometimes, for this reason, I called isofrequency and I did not look good. Why the split button does not update the data with the equipment? Pressing the split button on the program, the radio will change the setting ON/OFF, if I change the setting from the radio does not make any effect on the program and entering a QSO does not update the frequency split field tx_freq. I'm wrong in something?
Thanks de IKØCHU Mauro
#2 Posted : Friday, March 1, 2013 9:20:48 AM(UTC)
Most Icoms are not capable of sending the Split status to the computer. If you push the split button on the rig, LOGic has no way to know that you pushed it.
The exceptions are 7600 and 7800 with the latest firmware.
IK0CHU on 3/2/2013(UTC)
