Originally Posted by: WN4AZY  Hi Doug:
I suppose that the function keys in the data terminal COULD be used for this, IF the VFO swap could be accomplished by sending a simple ASCII string. But I don't think LOGic will let you assign the same port to a terminal and a rig. So while the function keys would work, the radio interface probably would not.
VFO selection is something that LOGic normally supports. What rig do you have?
Dennis WN4AZY Dennis, I would like to add that N1MM+ sends CAT commands to the radio quite easily (of course I don't know exactly HOW it is done). But I've been doing it for a long time. I have a K3 and a K4D here. 73, Allen N5XZ
