function key assignments
#1 Posted : Sunday, October 27, 2024 7:26:59 PM(UTC)
Dennis, is it possible to assign CAT commands to function keys? I have a Kenwood TS-590S, and I would like to be able to toggle between the 2 vfo's for working split while chasing DX/contesting. If possible, I don't want to use the mouse to do this. My keyboard keys are MUCH larger and more convenient than the tiny buttons on the radio are.
Thanks!
#2 Posted : Sunday, October 27, 2024 7:48:13 PM(UTC)
Hi Doug:
I suppose that the function keys in the data terminal COULD be used for this, IF the VFO swap could be accomplished by sending a simple ASCII string. But I don't think LOGic will let you assign the same port to a terminal and a rig. So while the function keys would work, the radio interface probably would not.
VFO selection is something that LOGic normally supports. What rig do you have?
#4 Posted : Sunday, October 27, 2024 8:24:36 PM(UTC)
Hi Dennis, the rig is a Kenwood TS-590S. I have attached the Kenwood command set manual. Also...I use a Microham Microkeyer. Their software uses virtual com ports.
ts590_g_pc_command_en_rev3.pdf (608kb) downloaded 0 time(s).
#3 Posted : Friday, November 8, 2024 2:41:39 PM(UTC)
Hi Doug:
Dennis, I would like to add that N1MM+ sends CAT commands to the radio quite easily (of course I don't know exactly HOW it is done). But I've been doing it for a long time. I have a K3 and a K4D here.
