LOGic Forum
LOGic Support
All Other
World Map - Rotor Direction
Posts: 619 Location: Mentor, OH
Thanks: 150 times Was thanked: 236 time(s) in 213 post(s)
This may have been asked before but would it be possible to have a thin line indicating rotor direction superimposed on the World Map ?? The line would run the full map edge to edge and reposition after a change in direction, could be a dotted line or dashed to distinguish from the others. Maybe a check box like Set Rig and Set Rotor that says Show Rotor.
Not saying I am going to do it, but what do you think about a transparent wedge approximating the width of the beam pattern, with the point on your QTH and the wide end running off the map?
Well....cool !! Being simple minded I'd be pleased as punch with a skinny line, bonus if it had an arrow on one end. All else is a cherry on top of the sundae !!
I won't hold you to either though.
LOGic Forum
LOGic Support
All Other
