World Map - Rotor Direction
#1 Posted : Sunday, October 10, 2021 9:09:00 AM(UTC)
This may have been asked before but would it be possible to have a thin line indicating rotor direction superimposed on the World Map ?? The line would run the full map edge to edge and reposition after a change in direction, could be a dotted line or dashed to distinguish from the others. Maybe a check box like Set Rig and Set Rotor that says Show Rotor.
WN4AZY on 10/10/2021(UTC)
#2 Posted : Sunday, October 10, 2021 12:41:01 PM(UTC)
Not saying I am going to do it, but what do you think about a transparent wedge approximating the width of the beam pattern, with the point on your QTH and the wide end running off the map?
#3 Posted : Sunday, October 10, 2021 1:24:26 PM(UTC)
Well....cool !! Being simple minded I'd be pleased as punch with a skinny line, bonus if it had an arrow on one end. All else is a cherry on top of the sundae !!
I won't hold you to either though.
