Posts: 214 Location: OR
It appears that Logic does not log a WSJT contact unless the log form "+" button has been pressed. I've lost several contacts because the form is not in the mode to enter QSOs. Could there be a modification so that Logic does log every WSJT contact regardless of the data entry mode on the form?
Bob, N7IP
Strange--you shouldn't have to touch LOGic. No matter what you are doing, it will in effect click the + button for you and add a new QSO. Click TOOLS/OPTIONS, and make sure CONFIRM SAVING NEW RECORDS and CONFIRM SAVING CHANGES TO MODIFIED RECORDS are not checkmarked. Also, make sure LOCK DATA is not checkmarked. Call me and I can log in and take a look. http://www.hosenose.com/remote_support.aspx
Tnx & 73, Dennis WN4AZY
Posts: 180  Location: Daytona Beach, Florida Thanks: 48 times Was thanked: 67 time(s) in 62 post(s)
Running LOGic 9.20.3 and WSJT-X 2.1.2 [with OmniRig 1.19 for my Yaesu FT DX-3000]. Logging working automatically...no actions in LOGic.
You can look at the .LOG file in"C:\Users\Bob\AppData\Local\WSJT-X\" with Notepad and you can see all QSOs in chronological order.
73s, Don
Posts: 28 Location: Israel
Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
I hope everyone is holding up well.
I am using Logic 9.20.3 and WJST 2.1.2. Everything imports as advertised except power level. It looks like Logic's default power level is used when importing.
I waited a long time for this version. It sure gets rid of the nuisance of importing the FT8 files all the time.
Thanks a lot, Dennis.
73, Jim 4X1RU
We're all healthy and doing fine.
There is a problem with LOGic not logging tx_pwr. I will fix it and it will be in the next update.
Posts: 301 Location: CT
I'm not seeing the issue with importing default power level. When I log a QSO, the Pwr field is blank because I have it set to blank in TOOLS > SETUP > Station Information > "Enter default transmitted power. This is entered in the log screen".
I am using: Window 10 Pro (v1909 x64-based system) Logic 9.20.3 WSJT-X 2.1.2
Vin, 73 K1VC
