WSJT logging issue
N7IP
#1 Posted : Monday, March 30, 2020 11:12:46 PM(UTC)
It appears that Logic does not log a WSJT contact unless the log form "+" button has been pressed. I've lost several contacts because the form is not in the mode to enter QSOs. Could there be a modification so that Logic does log every WSJT contact regardless of the data entry mode on the form?
Bob, N7IP
#2 Posted : Tuesday, March 31, 2020 9:47:41 AM(UTC)
Strange--you shouldn't have to touch LOGic. No matter what you are doing, it will in effect click the + button for you and add a new QSO.
Click TOOLS/OPTIONS, and make sure CONFIRM SAVING NEW RECORDS and CONFIRM SAVING CHANGES TO MODIFIED RECORDS are not checkmarked. Also, make sure LOCK DATA is not checkmarked.
#3 Posted : Tuesday, March 31, 2020 10:42:18 AM(UTC)
Running LOGic 9.20.3 and WSJT-X 2.1.2 [with OmniRig 1.19 for my Yaesu FT DX-3000]. Logging working automatically...no actions in LOGic.
You can look at the .LOG file in"C:\Users\Bob\AppData\Local\WSJT-X\" with Notepad and you can see all QSOs in chronological order.
73s, Don
WN4AZY on 3/31/2020(UTC)
4x1ru
#4 Posted : Wednesday, April 1, 2020 10:49:41 AM(UTC)
I hope everyone is holding up well.
I am using Logic 9.20.3 and WJST 2.1.2. Everything imports as advertised except power level. It looks like Logic's default power level is used when importing.
I waited a long time for this version. It sure gets rid of the nuisance of importing the FT8 files all the time.
Thanks a lot, Dennis.
Jim 4X1RU
#5 Posted : Wednesday, April 1, 2020 12:48:34 PM(UTC)
We're all healthy and doing fine.
There is a problem with LOGic not logging tx_pwr. I will fix it and it will be in the next update.
w2zi on 4/3/2020(UTC)
#6 Posted : Friday, April 3, 2020 11:48:03 AM(UTC)
I'm not seeing the issue with importing default power level. When I log a QSO, the Pwr field is blank because I have it set to blank in TOOLS > SETUP > Station Information > "Enter default transmitted power. This is entered in the log screen".
I am using:
Window 10 Pro (v1909 x64-based system)
Logic 9.20.3
WSJT-X 2.1.2
