LOGic Forum
LOGic Support
All Other
Using Data Terminal in Logic with a PK 232
Posts: 16 Location: Mechanicsburg, PA
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
I'm trying to setup my PK 232 with Logic. I am looking for the correct settings i.e. Baud Rate, Data Bits Stop Bits, Parity, Handshaking. Thank you.
Hi-- The settings in LOGic are in tools/setup/misc ham setup. As for what they should be set to, set them to match the PK-232. I am referring to the baud rate etc used to communicate with the PK-232, not the baud rate used by over-the-air data communications. Consult the PK-232 manual. This may be the right one: http://www.repeater-buil...bx-operating-manual.pdf
Tnx & 73, Dennis WN4AZY
LOGic Forum
LOGic Support
All Other
