Using Data Terminal in Logic with a PK 232
N3HR
#1 Posted : Sunday, June 10, 2018 11:31:58 AM(UTC)
I'm trying to setup my PK 232 with Logic. I am looking for the correct settings i.e. Baud Rate, Data Bits Stop Bits, Parity, Handshaking. Thank you.
#2 Posted : Sunday, June 10, 2018 1:52:49 PM(UTC)
The settings in LOGic are in tools/setup/misc ham setup. As for what they should be set to, set them to match the PK-232. I am referring to the baud rate etc used to communicate with the PK-232, not the baud rate used by over-the-air data communications.
Consult the PK-232 manual. This may be the right one:
http://www.repeater-buil...bx-operating-manual.pdf
