LOGic Forum
LOGic Support
Import and Export
importing adif file from WSJT-X, excluding dupes
Posts: 20 Location: MEMPHIS, TN
Thanks: 7 times Was thanked: 7 time(s) in 5 post(s)
dennnis
wsjt-x maintains a log file in adif format, it appends each qso to the end of its file. it uses this file to prevent you from working dupes.
the problem i am having is that when i import this file (append) a second time, all the records previously imported are imported again.
i would like to eliminate dupes on the import rather than having to make a copy of the wsjt-x file, and edit out all the records previously imported. then import the resulting file into logic.
your input is appreciated, as usual.
thanks much
buddy spiegel w3bs
LOGic does have a way to remove Duplicate QSOs. I erase the ADI file in WSJTX after each import into LOGic so I never use this utility so YMMV.
Click on Tools>Misc Utilities Select "Delete duplicate QSOs.prg"
Good Luck, Kyle, WA4PGM
LOGic Forum
LOGic Support
Import and Export
