importing adif file from WSJT-X, excluding dupes
w3bs
#1 Posted : Wednesday, July 19, 2017 8:54:03 AM(UTC)
Was thanked: 7 time(s) in 5 post(s)
dennnis
wsjt-x maintains a log file in adif format, it appends each qso to the end of its file. it uses this file to prevent you from working dupes.
the problem i am having is that when i import this file (append) a second time, all the records previously imported are imported again.
i would like to eliminate dupes on the import rather than having to make a copy of the wsjt-x file, and edit out all the records previously imported. then import the resulting file into logic.
your input is appreciated, as usual.
thanks much
buddy spiegel
w3bs
#2 Posted : Wednesday, July 19, 2017 5:45:49 PM(UTC)
LOGic does have a way to remove Duplicate QSOs. I erase the ADI file in WSJTX after each import into LOGic so I never use this utility so YMMV.
Click on Tools>Misc Utilities
Select "Delete duplicate QSOs.prg"
Good Luck,
Kyle, WA4PGM
WN4AZY on 7/23/2017(UTC), w3bs on 7/28/2017(UTC)
