Posts: 22 Location: Austin
With release 82 on Windows 10 (does not happen on Vista) I get the following message at startup: Error 1733 Class definition Logicserver.server not found has occurred Logicapp.after_init line 35.
Logic runs anyway after I dismiss the error.
Any ideas?
Bill N5VR
Groups: Administrators, Beta Testers Posts: 3,219  Location: Auburn, GA Thanks: 1111 times Was thanked: 539 time(s) in 451 post(s)
I tried this and it all worked without any error messages but the symptom is the same. Interestingly if I opt for the clean DB option the error does not show up until the clean and re-index is done. If I opt for ignore at that point then LOGIC 9 seems to run OK.
Bill N5VR
