Windows 10 Error
N5VR
#1 Posted : Sunday, January 24, 2016 12:02:34 PM(UTC)
With release 82 on Windows 10 (does not happen on Vista) I get the following message at startup: Error 1733 Class definition Logicserver.server not found has occurred Logicapp.after_init line 35.
Logic runs anyway after I dismiss the error.
Any ideas?
Bill N5VR
#2 Posted : Sunday, January 24, 2016 7:54:54 PM(UTC)
Try this:
http://www.hosenose.com/...n-----is-not-found.aspx
N5VR
#3 Posted : Friday, January 29, 2016 12:28:31 PM(UTC)
I tried this and it all worked without any error messages but the symptom is the same. Interestingly if I opt for the clean DB option the error does not show up until the clean and re-index is done. If I opt for ignore at that point then LOGIC 9 seems to run OK.
Bill N5VR
