2 Pages<12
LOGic crashes too often when moving VFO A or B
#23 Posted : Wednesday, February 10, 2016 6:27:12 PM(UTC)
Where is this located? I see Polling interval in seconds(polled rigs only) is set to 2.0
#24 Posted : Thursday, February 11, 2016 12:56:17 AM(UTC)
Tools>Setup>Misc. ham setup>Radio ifc
See attached
#25 Posted : Thursday, February 11, 2016 1:48:49 AM(UTC)
I am not sure of the setting beforehand but I see that polling is NOT checked when switching back to the K3 driver. I never have to reset the connection nor see the frequency revert 00.0000 and stay that way.
#26 Posted : Thursday, February 11, 2016 9:13:36 AM(UTC)
Hmmm.... Another mystery. I have to set my POLLING to ON to keep the frequency in the rig control window from reverting to 00.0000, but it causes LOGic to crash more often when I do that.
#20 Posted : Thursday, February 11, 2016 11:05:51 AM(UTC)
You know this computer has a serial port. I tried it but the rig goes to transmit. Going to reboot and look around, more later.
Try turning off DTR & RTS.
You're most welcome to stop by anytime and spend the weekend.
My parents would never forgive me hihi. But thanks.
#27 Posted : Thursday, February 11, 2016 11:18:21 AM(UTC)
Been doing web searches for this error. I haven't found anything related to RS-232 ports, other than one guy who was having problems with a USB=>RS232 adapter and getting this error.
The solution was to go to a DOS command prompt and do
SFC /SCANNOW
You might need to run the command prompt AS ADMINISTRATOR.
Probably not the problem, but easy to do -- you never know.
I was talking on the phone with someone yesterday about this, and he said that a Windows update included a new FTDI driver. Am I correct that this has become more of a problem lately? Other than adding polling, we haven't touched the K3 interface in years.
#28 Posted : Thursday, February 11, 2016 11:32:22 AM(UTC)
Yes, Dennis, but I've had this problem for years. Ever since I started using a K3, I have always had crashing problems. I cannot speak for any other K3/LOGic users, though. I have ruled out the K3 (tried several) and you have ruled out the microHAM. I do have an RS-232 SteppIR "Y" cable attached to the system, connected to the SteppIR control box. I cannot remember at this time if I ever did any long term testing without it, but I will disconnect it and try. However, there are others with the same problem, and I doubt all of them have SteppIRs. BTW, the SteppIR control box just sits on the RS-232 line and "listens" to the traffic, it does not send any data.
#29 Posted : Friday, February 12, 2016 8:26:56 AM(UTC)
Ran the command SFC /SCANNOW completed 100% with no issues found.
A new FTDI was released to brick the counterfeit adapters.
My adapter is using FTDI Version 2.12.0.0 dated 08/26/2014
N5VR
#30 Posted : Thursday, February 18, 2016 5:26:41 PM(UTC)
Hi All,
I'm sorry I didn't answer some of the questions but others did (correctly) on my behalf. I forgot the "watch this topic box".
I have been experimenting more and some of my symptoms conflict with those others are seeing.
I withdraw my comment that the problem is more associated with Sub than Split. I now agree it shows up when in Split.
I read something in QEX about how polling can mess things up on the K3 (since it sends info out on its own) so I looked at my set up and polling was off as I think it should be for the K3. Just for the heck of it I first made sure I could duplicate the error then I turned polling ON. After that I could not duplicate the error though I did still see some strange behaviors in the display window as before the OLE did not show up. This makes no sense at all. So I turned polling OFF again. Now I can't duplicate the error but I know it will be back. When it does I will try the DOS command thing mentioned above though I have no idea what it does.
I'll post something when it returns.
Regards.
Bill
Guest (12)
2 Pages<12
