LOGic Forum
LOGic Support
Error Messages
Partial file name error when entering terminal key
Posts: 50  Location: Manassas, Va Thanks: 1 times Was thanked: 10 time(s) in 9 post(s)
I started entering a file name path in the FILE_TXT() and then switched windows to get the complete path. When I tried to complete entering the file name I got this error:
FILE_TXT() cannot open C:\Prpgram Files (x86)\Logic Terminal Key Files\FTtxt. error 2. No such file.
Every time I placed the cursor over that terminal key entry I got that error.
The only way to get out of this condition to was to exit the Log form setup window and then re-enter it again without switching windows.
Fred
Hi Fred:
I see the problem.
Use FILETOSTR() instead -- no second parameter (buffer size) just the name of the text file in quotes as the only parameter.
I will update the documentation to reflect this change.
LOGic Forum
LOGic Support
Error Messages
