Partial file name error when entering terminal key
WD4ASP
#1 Posted : Saturday, March 3, 2012 10:43:42 PM(UTC)
I started entering a file name path in the FILE_TXT() and then switched windows to get the complete path. When I tried to complete entering the file name I got this error:
FILE_TXT() cannot open C:\Prpgram Files (x86)\Logic Terminal Key Files\FTtxt.
error 2. No such file.
Every time I placed the cursor over that terminal key entry I got that error.
The only way to get out of this condition to was to exit the Log form setup window and then re-enter it again without switching windows.
Fred
#2 Posted : Sunday, March 4, 2012 3:25:18 PM(UTC)
Hi Fred:
I see the problem.
Use FILETOSTR() instead -- no second parameter (buffer size) just the name of the text file in quotes as the only parameter.
I will update the documentation to reflect this change.
