Awards Progress List DXCCC Challenge
K6FW
#1 Posted : Thursday, November 21, 2019 2:51:13 PM(UTC)
Using the Awards Progress List for the DXCC award, sub award Challenge, results in the total Mixed DXCC displayed. In my case 332/340.
The DXCC Challenge Award is for band slots on bands 160-6 excluding 60 meters. In my case the total should be around 2400. The Challenge Subaward definition is not correct.
What is the correct award definition? The currently programmed definition is the one that ships with Logic 9.
Frank
K6FW
#2 Posted : Tuesday, November 26, 2019 2:40:38 PM(UTC)
Hi Frank:
I believe the definition is correct. In addition to 160-6 less 60, the DXCC must also be non-deleted and the QSO since Nov/15/1945.
QSO_DATE >{^1945-11-15} AND NOT LISTS.DELETED AND INLIST(ALLTRIM(BAND), "160M","80M","40M","30M","20M","17M","15M","12M","10M","6M")
The 332 count you are seeing is mixed. In other words, if you work say DU on all ten bands, it is only counting once. I think The 2400 you are expecting is the sum of DXCCs worked on each band. This is more like an ongoing contest, isn't it? Let me see if I can set up the contest scoring to get what you want. I'll post back here later.
K6FW
#3 Posted : Tuesday, November 26, 2019 3:48:31 PM(UTC)
The DXCC Challenge is the total number of bands slots of current countries 160-6 except 60 as you stated. . There is a sub award "Challenge" already defined in the Award Progress list. Only issue is it returns the mixed DXCC progress instead of the Challenge progress. The definition you posted above is what I see for Challenge in the Awards tracking setup criteria. Thanks for checking it out.
Frank
K6FW
1 user thanked K6FW for this useful post.
WN4AZY on 12/3/2019(UTC)
#4 Posted : Sunday, December 1, 2019 3:37:34 AM(UTC)
Frank is correct. It would be nice to see the total worked/confirmed for Challenge.
