Winkeyer form in Logic and Updated Firmware in Winkeyer
WB4HUC
#1 Posted : Thursday, September 12, 2019 1:16:54 PM(UTC)
Hello,
I recently updated the firmware in my WinKeyer USB to version 3.01.02 as shown in
the attached Winkeyer tools image capture.
When I bring up the WinKeyer form in Logic I get the message in the attached Winkeyer
form screen capture.
Seems like the Winkeyer firmware update changed something.
I should say that I'm using Logic Version 9.1.42.
Mike - WB4HUC
Austin, TX
#2 Posted : Tuesday, September 17, 2019 2:43:41 PM(UTC)
Hi Mike:
Sorry for the problem.
Please download and install 9.1.42 again. It will now display what is actually being returned by WinKeyer, and will ignore the bad return value and attempt to continue. Try that and see what happens.
Also, if you can provide a link to the documentation for the new firmware, that would be great.
WB4HUC
#3 Posted : Thursday, September 19, 2019 9:47:50 AM(UTC)
The Winkeyer USB is now working. Thanks for the quick update.
Here is the link to the Winkeyer firmware update:
https://www.k1elsystems.com/WinKeyer_31.html
Apparently there are two or three models of hardware, and there is a different update file for each
hardware version. My keyer is the Winkeyer with the SMT IC.
Mike - WB4HUC
#4 Posted : Thursday, September 19, 2019 6:35:42 PM(UTC)
Hello Mike,
I have always used HamGadgets' Masterkeyer MK-1 with Logic9, but after your post about the USB Winkeyer I had the curiosity to try.
I attach some screenshots before and after updating the USB Winkeyer with the Logic update.
All OK but the strange thing that the Firmware turns out to be version 85. It also happens to you ??
73's de IK0CHU Mauro
WB4HUC
#5 Posted : Friday, September 20, 2019 8:34:59 AM(UTC)
Yes, my WinKeyer form in Logic shows the same as yours...version 85.
#6 Posted : Friday, September 20, 2019 11:41:40 AM(UTC)
Hello Mike,
thank you for the confirmation.
I had the chance to try the Winkey v31 (RTTY) with other contest programs and Logbook but the reading of the version is correct.
If you have time try it yourself so that we have cross-checks.
However important it works and if the version number is projected towards the future it is better so we can say that we are at the forefront. (Winkeyer UFO 85) Eheheh
Thanks Mauro
