Trying to insert UTC in terminal keys in log form
#1 Posted : Sunday, July 28, 2019 11:28:13 AM(UTC)
I'm trying to insert the current UTC as part of one of the terminal keys in the Expression Builder.
I can insert current local time, QSO time (on/off) but cannot seem to get UTC.
Was also trying to insert my QTH from LOGic setup. Could not find that variable so I hard coded it. (Not possible for current UTC.)
Thanks and 73s,
Don, W2ZI
#2 Posted : Monday, August 5, 2019 2:44:51 PM(UTC)
Sorry I didn't see this.
The expression you need is
global.utc_time
It returns a 6-character string.
global.utc_date
returns the current date as type date
#3 Posted : Sunday, August 11, 2019 1:27:01 PM(UTC)
Only had partial success.
Both variables work in the Database Commands window:
? MDY(global.utc_date)
and
? global.utc_time
HOWEVER, only the global.utc_date works in the terminal key macros.
Putting global.utc_time in the macros is rejected. Also tried several of the time-related functions on it with similar rejections.
Thanks for the help,
73s, Don
#4 Posted : Monday, August 12, 2019 3:17:54 PM(UTC)
Ok, are you saying that it won't let you enter
global.utc_time
as the expression in log/setup in the terminal keys tab?
I had no problem, and tested it and it worked on Telnet.
#5 Posted : Monday, August 12, 2019 7:26:22 PM(UTC)
Here's the error I get in the form setup. It will still allow me to 'OK' and save the changes. When I hover over the particular T macro, the crashes.
Don
utc time error.jpg (96kb) downloaded 147 time(s).
This page was generated in 0.455 seconds.
