LOGic Forum
LOGic Support
Form customization
Trying to insert UTC in terminal keys in log form
Posts: 180  Location: Daytona Beach, Florida Thanks: 48 times Was thanked: 67 time(s) in 62 post(s)
I'm trying to insert the current UTC as part of one of the terminal keys in the Expression Builder.
I can insert current local time, QSO time (on/off) but cannot seem to get UTC.
Was also trying to insert my QTH from LOGic setup. Could not find that variable so I hard coded it. (Not possible for current UTC.)
Thanks and 73s, Don, W2ZI
Groups: Administrators, Beta Testers Posts: 3,266  Location: Auburn, GA Thanks: 1145 times Was thanked: 555 time(s) in 465 post(s)
Sorry I didn't see this.
The expression you need is
global.utc_time
It returns a 6-character string.
global.utc_date
returns the current date as type date
Dennis, Only had partial success. Both variables work in the Database Commands window: ? MDY(global.utc_date) and ? global.utc_time
HOWEVER, only the global.utc_date works in the terminal key macros.
Putting global.utc_time in the macros is rejected. Also tried several of the time-related functions on it with similar rejections.
Thanks for the help, 73s, Don
Ok, are you saying that it won't let you enter global.utc_time as the expression in log/setup in the terminal keys tab?
I had no problem, and tested it and it worked on Telnet.
Here's the error I get in the form setup. It will still allow me to 'OK' and save the changes. When I hover over the particular T macro, the crashes. Don
LOGic Forum
LOGic Support
Form customization
