Posts: 9 Location: NY USA
Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
I tried to import file from OMISS Net for membership list.. It did not work because of Omiss file location and also that it is now a txt file.. Logic requiers it to be dbf file.. Question: is there a simple program out there that can convert my txt file to dbf?? Or is there a way to capture the txt with logic?? Tnx to all!! Larry
Posts: 474 Location: Missouri
Thanks: 103 times Was thanked: 161 time(s) in 143 post(s)
Save the list to your computer and import it from there. I just did it, and it works fine. 73 Doug W5GA
tnx for the reply.. I did that already.. I have logic 8 and the file needs to be a dbf file.. It will not import a txt file, and will not give me a choice.. Thanks!
Thanks again
Larry
I've got Logic 8 also...I just did it. 73 Doug W5GA
Hello again,
Sorrybut i dont know what you are doing but i can not find any way to get logic to upload file. Can you explain how you did it pse?
Tnx again
Larry
In the import window, change the address at the top to C:\temp\omiss-roster.txt (that's where I put it on my machine), then click the "begin download" button. 73 Doug W5GA
