RST fields not filling when importing adif files
KB7EEG
#1 Posted : Saturday, April 13, 2019 3:02:17 PM(UTC)
Hello Dennis,
Running Logic9 ver. 9.1.39
almost everytime I import an adi/adif file from any other program it does not import the RST S/R fields, As my log is full of this kinda stuff. How do I mass edit it so I can make the S/R fields 59 or 599 between this date n time to this date n time??
#2 Posted : Sunday, April 14, 2019 7:56:25 AM(UTC)
This will help get you started.
http://www.hosenose.com/...tst768_Mass-change.aspx
Be sure to make a backup of your log first!!!
WN4AZY on 4/14/2019(UTC), KB7EEG on 4/14/2019(UTC)
#3 Posted : Sunday, April 14, 2019 3:47:35 PM(UTC)
Thanks Kyle.
Also
https://www.youtube.com/...?v=5d5gyJVFQEs&t=5s
We need to see why LOGic isn't importing the RST fields. Go to tools/setup/log fields and look at the RST_SENT and RST_RCVD fields. Make sure that Import and Export and Basic Fields is turned on in the ADIF tab.
If that is all good, post a sample ADIF file here.
KB7EEG
#4 Posted : Sunday, April 14, 2019 9:47:26 PM(UTC)
Thanks Dennis, I wish I could find those .adi/.adif files there somewhere around here on one of these thumb drives or cd's LOL if I find them will send u the whole log.
Chris/KB7EEG
N7IP
#5 Posted : Sunday, May 12, 2019 1:56:15 PM(UTC)
Dennis, I have a related import problem. Logic does not lookup the address of an entry such as from WSJT. I discover this only when I print QSL envelopes and don't have them for the imported contacts. See attached screen from Logic. Seems like Logic should add the address during import. Thanks,
Bob, N7IP
logic.pdf (542kb) downloaded 131 time(s).
#6 Posted : Sunday, May 12, 2019 9:04:07 PM(UTC)
Hi Bob:
First look at the ADIF file (it's just a text file), and make sure it has ADDRESS in it. If WSJT is not exporting address, then you can use tools/callbook batch update to find addresses from your callbook(s).
If it is exporting address, then post a copy here and I will see what is going on.
