Groups: Administrators, Beta Testers Posts: 3,256  Location: Auburn, GA Thanks: 1134 times Was thanked: 553 time(s) in 463 post(s)
Sorry, I overlooked the question on defaulting the mode to FT8. Thanks Kyle.
For "invalid mode" you can also, install the latest update, and select the option to install the factory prefix table. It has all of the ARRL/LoTW approved modes.
On the Comm state, what sort of hardware are you using? Look at it in the device mananger. Is it OK? If another program is using it, LOGic, or more precisely Windows, should detect that and give an appropriate error message, but that doesn't always happen. Also, make sure that nothing else in LOGic is trying to use that port. Does Tools/advanced/serial port status show anything screwey?
Which radio driver are you using in LOGic? One of the non-legacy drivers should give better error reporting, and be more tolerant of USB=>RS232 devices that are not 100% compatible. And you do have the latest (9.0.41) update to LOGic, right? The com port code was done in .37. There have been a few fixes since then.
